K
kyda
ok, i'm getting ready to setup my home studio. i play drums and will be mostly using this setup to record multi-track/layered drum/precussion ideas, but also to record my band. i'm considering going the digital pc route and had a few questions. it looks like a lot of you have or recommend the darla and alesis 12r setup. are the two inputs on the darla going to be enough for me to record drums? i'd like to have individual control over my snare, kick, toms, etc. once their recorded to my hard drive but also be able to lay down the whole set at once. should i look for a card with more inputs? if so, any recommendations on one at or around the darla's price? i've seen a 4 in/4 out card from midiman, any good? also, is there a mixer/pre-amp that is comparable to the 12r that is not a dedicated rack mount? i'd kind of like to stay away from anything rack mounted...
now something off topic if you don't mind: what is the best way for me to be able to record my drum tracks but get a guitar/bass headphone mix so i can play with the rest of the band but isolate the drums? will any headphone amp or personal monitor amp work,
or is there something i'm missing about this technique? thanks.
ps-i'm assuming once i record one set of tracks, i can assign them to the outputs on the sound card, run them through the alesis and into headphones so i can hear them while playing the next set of tracks? can i do this and still use the alesis to mix into the inputs on the card?
thanks so much for your time...
d a v e
d a v e
