kidkage
Bored of Canada
I tend to make really long posts, so I'll try to keep to the point.
Ok, here goes nothing:
Here's where I'm at. My current set-up:
Interface- Tascam US-1800
"Outboard(...that I use)"- PreSonus Studio Channel, M-Audio DMP-3
DAW- Cubase 6. Win. 7 64-bit, 750GB hard-drive, 16GB RAM, AMD Phenom II X4 (Quad Core, 6MB L3 Cache, 2MB L2 Cache, 3.70 GHz)
Monitors- KRK Rokit 6's
Here's where I want be/ what I want to upgrade and/or add to (I'm not wanting to go more than $2k per category. Obviously I'm not a gear snob. So if the best piece of equipment between $0-$2000 is $50 that's fine. I'm just setting the cap at 2k per category):
Interface-
My main area of concern and confusion is upgrading the interface. Most of the higher priced ones look nothing like the Tascam, and seem to have a limited number of inputs. I feel since I want to improve my setup, the thing that does the A/D conversion, the most necessary part of the recording process needs to be "pristine". I don't know much about costly gear though. I've compared mixers to rack units and have came to the conclusion that the eq on a mixer would basically be useless to me. The Steinberg interfaces (I am using Cubase after all) and the RME Fireface 800 seem to stick out to me at first glance. The steinbergs seem to only have 8 inputs though
. The fireface 800 in particular seems a little confusing compared to the us1800 though. It (us1800) has 8 xlr inputs and 2 line ins on the front with preamps, and the back has 4 line inputs that i have a mixer and the dmp3 outs plugged into. The fireface has 4 preamps on front, and 8 line in's on back...but the description says "56 channel"
Can someone help me understand how exactly I would work with something like that?
And if anyone has any other recommendations throw em at me
"Outboard"- I've got my eye on the UA 4-710d. I want good preamps. And 4 is perfect. I could run vox, bass, guitar, four main drum mics, whatever through it. I figure once I upgrade the interface I would set the 4 UA channel onto the line channels of the interface. I'm sure there's no need to pair them with the interface preamps.
DAW- Don't see any need to change the current setup.
Monitors- I want to add a set to A/B. And upgrade at the same time
. The ADAM A7 and A8, and JBL LSR4328P seem to stick out to me. Any opinions on those? I'm obviously looking up reviews on them and am finding good and bad for all, but come on... HR opinions make the world go round.
The final question: Since buying all of this stuff at once isn't an option for me, I'd like to know what the best order to upgrade these things in is. ?
And don't worry. I know. The room, and treatment are being taken care of
Interface-
