Some good monitors that sound as my headphones when using Guitar Rig 4?
  • Thread starter Thread starter TheComposer
T
TheComposer
Hello, when i use Guitar Rig 4, i use it with my headphones, every single time. I'd like to have some small monitors to connect them to my laptop and playing without my headphones, what are the good/obvious choices out there?, I'd like some cheap options, but you are free to mention what you think it'll sound the job right, thanks.
What's your budget? Are you recording? If so, you want flat response monitors. Remember that most headphones give yo increased bass volume, so what you hear the speakers will sound different.
Hi, well i was thinking something over 100 USD or less maybe?
I just recorded my tracks using headphones actually, couldn't be happier with the result, but i'd like to have some monitors just for practice, nothing too fancy, probably a single monitor will do the trick
I saw a pair of Rokit 5 first generation monitors at a local GC for $99.00 I got my M Audio Studiophonic 5's on Ebay for under $100, but you won't find much anywhere for that price.
If you are recoding/mixing with headphones, don't you notice, when you burn a CD and play it on a stereo or car system, that it sounds a lot different?
Well mjbphotos, i took my tracks to an engineer (He'll mix my tracks later) and he had his JBL monitors, it was a killer sound!!
"You took your tracks" - you mean not a finished mix - two different things. Headphones are fine for tracking. If you use them exclusively for mixing, your mix will not sound the same through speakers.
My bad, he's going to "master" my tracks, just adjust volumes.
