Soft Synths with Digi001/ProTools ?
  • Thread starter Thread starter JKZ
J
JKZ
Hi..
Just deciding on which software to go. I'm quite a beginner when it comes to DAW. I'm looking at Delta 1010 with Logic Audio or Digi001 with ProTools.
I think I'll be using Soft synths in a big way. I know a lot of them exist for Logic...but are they equally available for ProTools LE platform?
Protools with Digi 001 supports RTAS (Real Time Audio Suite), which is it's own plugin standard.
You can use VSTi, with a program called UGLY VSTi , which is a shell that let's you use vsti in Protools. You connect them with DirectConnect, which is the Digi's version of ReWire.
You have one free synth called Vibra 1000, from Koblo. And they also have Vibra 9000, which VERY PHAT.
Other DirectConnect synths are the ones made by Native Instruments, like the Hammond, the DX7, Reaktor and stuff.
Cheers, Andrés
One synth is all you get with ProTools LE? You mean to say if I use DirectConnect I can work with all the Native Instruments and others synths in ProTools?
Does Reason work with ProTools?
How about GigaSampler?
You don't get any synths with PT. You just get the Digidesign plugins. You can download Vibra 1000 by Koblo , which is free.
DirectConnect is supported by many, including Native Instruments.
With the UGLi VSTi, you can use VST instruments. There are plenty of them, a lot free. I didn't try this myself, you should go to the digidesign forum and make a search on that to see how are actual users doing with it.
Reason doesn't interface directly with Protools. Reason uses Rewire, which is another story. There are two ways to interface PT and Reason. The first is running the mac's audio out into the Digi 001. You can record or monitor. If you don't like the quality, you can just record and when you're ready for the mix you can import the Reason loops into PT, thus keeping the quality. You won't have track separation cause you're importing the master stereo track, unless you export one track at a time from Reason.
The other way is to buy a cheap digital out card, put it in another PCI slot on your computer, and then run those digi outs to the Digi's 001 digital ins. That is more expensive but you keep the quality and you can do channel separation. I heard such cards cost like $300 in the States.
For deep details on this, goto here . Since both programs are cpu hog, check that your machine can handle both of them.
My advice is to download PTFree, then Reason's demo, then the UGLY VSTi and try them together without spending any money.
Cheers, Andrés
hey Andres, thanks a lot man. Was a lot of help.
Looks like Logic is a lot more flexible with soft synths? I'm tempted to go that way.
Anybody out there using Soft Synths with Logic/ProTools? Any suggestions?
no problem.
My advice is that you check cubase too. Steinberg (the makers of Cubase) are the guys who originally developed VST. Plus they are very close partners with Propellerheads, the maker of Reason and Rewire.
If you're going to match different cards with different software (like Protools with Logic) check for latency issues.
