mark4man
MoonMix Studios
Crew,
Looking to expand my instruments capability; & may go the way of a Software Sampler (more than likely Tascam's GigaStudio.)
I am presently used to deriving many of my sounds from a sound module (Roland JV-1010); & have become set in my ways...(so please forgive the following questions if they seem too obvious):
[& sorry for the parallel post...but I think I've got my direction now]:
1) Is it (GigaStudio/Solo) compatible with SONAR XL 2.2...& does it operate as a typical plug-in?
2) I would like to use it (for now) in place of my sound module [to obtain (from what I've heard) more "realistic & varied" sounds]; & so I would like it to operate in the same manner...so:
Does it play individual sampled notes as triggered by a MIDI source? (in my case, MIDI sequences of pianos, keyboards, drums, horns, synths, etc., composed in SONAR MIDI tracks.) If so, do conventional libraries (such as for piano) contain these note samples (of various length & velocity) along with their standard loops & riffs? (Can libraries of notes only be obtained?)
3) One of the advertisements I saw, read: "ReWire - MIDI from DAW software is routed to GS3; GigaStudio audio is sent to the DAW, where it shows up with its own mixer section".
I know that seems to answer question 2 (except for the individual notes part)...but I thought that ReWire was an audio application in & of itself. Do they mean that app, or was that just a routing term?
Again, forgive the obvious...but GS3 would play the sampled notes as a plug-in module, whereby they could be recorded directly into the SONAR audio track?
4) GS3 streams exclusively from the hard disc? Isn't loading & streaming from RAM faster (less latency)? (I have lots of RAM.)
5) Existing libraries (I'm most interested in piano, right now)...do soft-sampler samples sound better (more depth, ambience & realism) than those generated by sound modules?
Thanks very much,
mark4man
Thanks very much,
mark4man
