D
darwin
After reading the information provided in the SAE site, I really think it would be good for me to wall-mount my Mackie HR824s. However, after searching this forum on the topic, I am confused about the following post by Barefoot. I really want to soffit these speakers, but I don't want to make a colossally bad acoustic construction. Please, could you clarify the following issues?
https://homerecording.com/bbs/showthread.php?postid=233186&highlight=flush#post233186
Specifically, I don't understand the following statement and how it relates to soffit-mounting Mackie HR824s.
"1. No rear cavity - The problem with this one is self evident. The baffles must be "free floating". You can either suspend them from the ceiling or from an open frame mount. "
-I will treat your assesment that a rear cavity is problematic as gospel. I just don't understand what I should do. Should the back of the speaker rest directly against a wall built into the rear of the frame? I think a huge problem for me is that I don't understand what you mean by a "baffle" in this type of scenario.
Also, on the HR824s, there are several different ways that you can set the monitors up. For example you can set them up to be in the very corners of a room, or you can set them up to be more in the middle of a room. The dimensions of this control room are 10.42 ft (wall that speakers would be mounted against) X 11.83 ft (length) X 6.8 ft (height-it has a 4 in drop ceiling)
I had planned on putting some acoustic panels per SAE site under the monitors.
