BrettB
hi all,
I got a bit confused by a post about insert points recentely.
What I know, of think is right, let's put it this way: an insert point is an out/input after the pre-amp, used for some prefade compression or Eq (at least this is how I use it). In a previous post I read that when you got no direct outs on your channels you can use your insert point as tape output. I never heared of that kind of use.
So if you use it that way, it is off course used prefade, and so you use you're mixer for monitoring, I mean: you can't use your faders to balance the inputs?
Or is there a hiatus in this point of view?
