Slackmaster2K
Gone
Tonight I finished playing "electrical engineer."
I built a godawful ugly signal splitter for about 15 bucks in parts.
The box has one stereo input in the rear and 4 stereo outputs on the front. Each output has an on/off toggle switch and there is main mute toggle on the top of the box.
I did a horrible job drilling the holes so they're not level...and the toggle switches I got look like something from an old 50's sci-fi movie. Kinda cool really.
Anyway, the point is that I run a patch cable from my soundcard's output into the input of this box. Then to each output on the box I plugged in my monitoring sources....two pair of headphones and two pair of cheap speakers. Prior to making this box I had to reach around an manually plug the various speakers into the soundcard which was a pain in the ass. Now I can switch between sources with little switchs right in front of me. I designed it such that I can select any combination of outputs too which is kind of handy. Basically it's a fully-switched breakout box.
BTW, don't ever let anyone tell you that a soldering iron is easy to use...man I need three hands. The wiring is so damn ugly...but it works and doesn't seem to add any noise (I used shielded cable and a shielded box).
Slackmaster 2000
Slackmaster 2000
