Bassman Brad
In my earlier post, I explained that I'm in the process of trying to assemble a PC-based home recording setup. I ordered the Presonus Firepod from Musician's Friend, but was one day too late to get the free firewire drive that they were throwing in for a period of time. (However, I will still get the AT2020 mic.) I had assumed that I would just have to go out and buy a firewire drive myself. However, I've been told that installing a second hard drive in my computer would be a better option. Is this correct? I thought the Firewire was supposed to be extremely fast, and designed specifically for streaming media.
My PC is an off the shelf HP with 1.5 gig Pentium 4 and 700+ meg of ram. However, I'm not sure that the HPs even have enough physical space in the case for a second hard drive. So, I would presumably have to buy a new case, the new hard drive, and then have my computer whiz nephew to install everything in the new case. (Might as well use the opportunity to install a quieter fan, too, while I'm at it.) So, this is looking like a fairly expensive and complicated endeavor. Wouldn't a firewire drive be a lot simpler?
Also, I understand that the firewire spec allows for daisy chaining of devices. I only have one firewire port on the machine. Does this make a difference in deciding if I should go with a second hard drive or an outboard firewire drive? If I do need a firewire drive, are there particular specs that I should pay attention too? I understand that any hard drive will work for audio, as long as it's rated at 7200 rpm. Is this correct?
Thanks,
Brad
Thanks,
Brad
