R
Rickson Gracie said:i have a ludwig fag 4 reissue kit.
everytime i hit my 1st tom the snare buzzes. i can stop it by tuning the tom high but it doesnt sound good to me like this. i found the sweet spot and i want the snare to cooperate with it.
any suggestion on how to fix this? thanks.
Reducing sympathetic buzz:
When a drum or a certain note from other instruments causes the snares to buzz, this is called sympathetic vibration. This happens because the vibrations traveling through the air cause anything they come in contact with to vibrate at the same rate (pitch). If the resonant frequency (the pitch at which it resonates the most freely) of an object happens to be the same as or close to that pitch, it will easily vibrate at that pitch. This is why only certain toms or certain notes from the bass guitar cause the snare drum to buzz loudly. There are a few cures.
-Tune the offending tom to a different pitch.
-Tune the snare-side head to a different pitch.
-Tune the batter head of the snare to a different pitch.
-Detune the lugs on either side of one or both ends of the snares (on the snare-side head). This, in effect, makes the snare-side head to be out of tune, so its resonant frequency won't be as strong.
-Put duct tape on the snares. [This is not my idea. In fact, it's a stupid idea. Not only will it prevent most of the sympathetic vibration in the snares, but it will also prevent the snares from working freely, like they should.]
it will still probably buzz after tightening the snares but it shouldnt buzz alot, really the only way to really get rid of it is to tune the tom and the snare so they are different and arent taking us the same rangeJoeyPazera said:you need to tighted your snares.
if you dont know how, switch off your snare, then the screw thing turn right a couple times, and turn your snares on again. that should make your snare alot tighter sounding and wont buzz when anything loud happens.
rushofblood said:it's a good thing.
Any particular business?cyclone said:Place a business card under your snares ...
those are just decorations.....cyclone said:..and tampons all over your drums...
