rob aylestone
Moderator
I did a video last week and compared some mics, and for the first time ever, an SM57 did a bad job. Just thin, but when I investigated pulling the plastic end ring away from the mic, it restored to normal.
This seemed odd and worthy of investigation, so I pulled out my collection of broken mics (the idea was to fix them over the quiet periods, but it never happened.
I pulled apart a dead one. I remembered that I started a spreadsheet with resistance values for capsule and transformer wires, and found that the transformer measured fine and the first mic had an open circuit capsule. I then removed that capsule, and took the end cap and perforated screen off. I repeated this process for the qeird sounding one and the capsule measured out normal. I removed the end cap and looked at the diaphragm. Dead centre was a little black 'microturd' - the best description I have. The end cap has plastic in the centre - sound gets through via 7 circular ports, so I am assuming the spec is a collection of tiny foam fragments that have gradually coalesced with spit into a little lump dead centre. eventually it grew to the size where it touched the centre of the cap, and that's what changed the tone. I'm pretty sure this is the very first one I bough from the 70s, so this probably isn't really bad, is it? Looking at the others in the box - there are two with open circuit capsules - I did look for a replacement, but the only so called genuine ones are clearly not.
