J
JuliánFernández
2&4
Hi Guys! Look what i found on Soundcraft site (btw, some cool data and links : http://www.soundcraft.com/palz.asp )
FAQ Section:
Can I use +48v Phantom supply with dynamic microphones connected to the mic XLR inputs?
It is possible to use BALANCED dynamic microphones when the +48v phantom is on. The microphone coil 'floats' up with the voltage preventing damage to the microphone by ensuring 'zero' volts across the microphone coil.
If the dynamic microphone is configured UNBALANCED (where pins 1 & 3 are connected together), then the dynamic microphone will be damaged. This is because one side of the microphone coil is connected to ground, with the other side connected to +48v. Thus, +48v will be across the microphone coil causing it to burn out.
Always ensure the Mic lead is balanced when using +48v phantom power.
Ok, so, the question is... Can i damage my SM57 and my D112 if i use an standard xlr cable and phantom... (in the firepod you only can asign phantom 4 channels at the same time, so in some setups i "need" to send +48v to the 57 and the 112 too)
FAQ Section:
