B
Bob Mould
i was thinking about the design of slot resonators the other day, especially the difference in horisontal slats vs vertical slats.
I know that if u have a straight wall where the depth from wall is fixed then it would not matter which way you go 'cause horisontal slats and vertical slats would be equally efficient, but if you have an angled wall what would apply then?
For example if the slats are horisontal then each slat would have a broad frequency range because the depth from wall would vary from the deepest point to the narrowest point of the slat. But if the slats are vertical every slat would have a narrow absorbtion at a specific frequency 'cause the depth from wall would be fixed.
This of course only applies if you keep the slat spacing constant all along the slat. Varying the spacing along the slat would give a broader absorbtion frequency in both cases but when the slats are horisontal then the depth from wall also varies giving even broader frequency absorbtion abilites per slat.
To me it seems that vertical slats would be more flexible on angled walls as they can be both narrow and broad in its absorbtion. Am i thinking right here?
What should one aim for in a control room, the broadest low to low-mid frequency absorbtion possible or being able to control specific frequencies?.
Also is there a way to calculate the amount of absorbtion a slat will have?, For example if i have a room with a 5db raise at 200hz is there a way to calculate how many slats absorbing 200hz i will need?
Thanks
Mike
Thanks
Mike
