Samuel LB
Hi, all – brand new here. I'm trying to learn to work in slide-tape format (35mm film slides shown via a projector controlled by a cassette tape which is also playing back audio). I'm brand new to working with cassette tape and am up to my ears in formats and speeds.
I'm working with a Sharp RD685AV dual slide projector remote and cassette deck with built in loudspeaker. It records and reads the entire tape in the same direction – cue track on top and audio on the bottom (ANSI Philips 2tr tch format).
I can live-program cues (1000hz or 150hz pulses) onto the tape using this device (pushing buttons as the tape plays), but since I'm trying to synchronize the slide advances to music, it would be simpler to lay it out on a computer: pushing the on the beat button •starts* the frame advancing on the beat, with the image *appearing* on screen about .85 seconds later. I want the image to *appear* on the beat instead. I guess I could time it all out, make a score, and try to follow along, but it would be so much simpler to do it in all in a DAW.
SO! I borrowed a Tascam 414, which reads and writes, as I'm sure you all know, in TEAC 4ch 4tr format, from a friend, and put a cassette with audio and cues recored on the Sharp machine into it. The audio seemed to play on channel 1, and the cues on channel 4. So far so good.
I laid out the music and cues in Audacity in two mono tracks, with one panned hard right and the other panned hard left. I sped everything up 100% to compensate for the 2x write speed on the Tascam. I used a y-cable to split the signal from the computer (via the headphone jack) to the inputs for channels 1 and 4 and set levels. Channel 1 seemed to have the audio going into it, as it should, and channel 4, the cues.
I recorded a test and put the tape in the Sharp machine. The audio played back at the correct speed, but the slide projector didn't advance.
I tried another test, this time recording the cues on two channels (3 and 4), and tried it in the Sharp machine. Still no dice!
I can think of a few other things I could try – making the pulses longer, louder, ect., and I will get back into that tomorrow, but in the mean time, I'm hoping that there's a simple answer – either that I've missed something obvious, or that it just isn't possible to do what I'm trying to do using the Tascam, and I ought to track down a different cassette deck to do the dubbing with. If anyone is familiar with slide-tape or any of the devices in question, could you please let me know?
THANKS IN ADVANCE!!!
Best,
Samuel
Best,
Samuel
