H
HapiCmpur
Anybody ever use one of these humidifiers?
http://www.zzounds.com/a--2676837/item--SKBCLIP6
I bought one before I realized that the first two times you use it you're supposed to soak it in an "activator solution" that contains propylene glycol. You can use plain water after that, but I'm understandably leery about putting antifreeze in my guitar case.
I was wondering what that flap looking thing was for.
Actually now that I've looked a little closer, it's a pretty cool little item. Still a little over priced though.
). You should be fine as long as it's not dripping wet. If you're that concerned, you could always do a couple of wet dry cycles outside of the case and switch to water before introducing it to the guitar. I guess it depends on what the solution is supposed to be doing in the first place. If it's to keep moisture from freezing in the case, don't worry because the guitar should never be out in the cold for that long. If it's to condition the element, then I would use it.
