M
Mike Freze
Hello Again! Just a question about recording midi as audio initially right along with the other audio tracks in a project (I use Cubase).
I understand that midi takes up very little hard drive space to record the data as midi files alongside of your audio (analog) tracks. What I don't understand is this: if you have to convert those midi tracks to audio down the road in order to mixdown (bounce) all your tracks to a single stereo audio file for final exporting, isn't the size of the audio file (say, WAV) going to be the same after you converted those midi tracks to audio as it would have been if you did everything as audio to begin with??
If so, how is that going to help lessen the stress or demands on your computer (or take up less hard drive space) when it all ends up that way as audio anyway when you go to mixdown your project? I know recording midi as midi tracks (data only) is great for detailed editing and "temporary" smaller-sized tracks, but what difference does it make if it all has to be audio in the end??
Thanks!
Mike Freze
Thanks!
Mike Freze
