Tyler, what the sidechain is, is a place to break into the compressor's inner circuitry, and either modify the response of the compressor by changing the characteristics of the signal you're compressing (such as changing the EQ so the opposite effect will happen at the output, by that portion of the signal being affected more or less than other frequencies), OR, you can (as bear said) feed a totally different track/signal into the sidechain, causing the compressor to change the gain (level) of the MAIN input ONLY when there is signal coming into the sidechain connector. When you feed an announcer's vocal track into the sidechain and the music bed into the MAIN input, every time the announcer speaks the music is lowered in level, or "ducked" - the level you feed into the sidechain determines HOW MUCH the music level is reduced, along with the settings on the compressor itself. Now, lets see if the subject is even the same, or if there are 25 more posts to sort through... Steve
