J
Jarick_2
Hello everyone,
I'm moving from a VS1680 to a PC-based setup, and I'm looking at soundcards right now. I've got a nicely equipped Shuttle SFF PC right now with an SB Audigy in there. A large portion of recordings will be a close-miked drum kit (10 channels or so) or recording several acoustic instruments at once, so I'm looking for something that has at least 10 channels. I am planning on using an M-Audio Octane as a preamp, which will have A/D converters and an ADAT output.
I've been considering going the firewire route with the forthcoming M-Audio Audiophile Firewire 18/14, but recently I've found a lot of support for the EMU 1820. Because the SFF computer only has one PCI slot, I'd be replacing my soundcard, and I'd like to know if the EMU works fine for standard PC use. Also, how does the RME Hammerfall (specifically the DSP 9632) compare with the EMU?
So does this sound like a reasonable setup? Do you have any experience with it at all?
Thanks
Thanks
