Show Volume Envelopes
  • Thread starter Thread starter Leonsky
L
Leonsky
How to enable and make Volume Envelopes not in MULTITRACK VIWB but in normall EDIT VIEW ion COOL EDIT PRO :)
peace :)
You can only find and use volume envelopes in Multitrack. Volume envelopes don't live in Edit View.
If you've got something in Edit View and you want to apply volume envelopes to it, you have to send it to Multitrack: Edit>Insert in Multitrack.
but when i save some modified mp3 from Multitrack to EDIT VIEV there is no any changes
like nothing save in Multitrack Edit:confused:
You need to make all your changes in Multitrack View, then go to Edit/Mixdown and select "all audio clips" or "selected audio clips;" CEP will mix to a stereo or mono track (depending on what you tell it to do) in Edit View and all the Volume Envelope and other changes will be preserved.
Simply applying volume envelopes to a track on Multitrack View and then transferring to Edit View does not transfer any changes applied in Multitrack View.
THANKS :D
It works :)
