J
jshailes
I'm a complete newbie when it comes to audio recording so apologies if I'm asking an obvious question! I've just purchased a Blue Yeti microphone, primarily for recording webcasts, and am concerned that the slight high pitched background fuzzyness shouldn't be there. Is this a valid concern?
Things I've tried so far:
- With the mic connected to my desktop, I've moved the mic closer and further away from the pc but there seems to be no difference.
- Changed USB port the mic is connected to, no difference.
- Connected mic to laptop, no difference.
Once again this is probably obvious but the problem is much worse when the volume is turned up high.
I read on another forum that someone suggested connecting to a powered USB hub so maybe this is worth a try.
I've seen a frequency analysis done with audacity to show where in the spectrum the noise is, would this be useful for identifying the source?
Lastly but not leastly, can someone confirm if it is/isn't reasonable to have any amount of noise from the mic?
Many thanks,
James
Many thanks,
James
