famous beagle
The composition is very niceAre you wise in the ways of theory? Do you check out Rick Beato's "Everything Music" channel on YouTube? It's FANTASTIC.
Sounds really good as well. What is done with regard to processing? Sounds like some stereo image stuff is happening on the different sections. Are you using compession/limiting on the mixbuss? Or are all of the libraries pre-tweaked, kind of like EZDrummer 2 vs. Superior Drummer?
Sounds like a real score IMHO. Well done![]()
Thanks! I do know theory. It was my major at UNT, in fact. I've seen some of Rick's videos; His son's ear is absolutely unbelievable!
I just checked the project in Reaper, and I didn't really process anything. The only thing that's there is some concert hall reverb that's from the Aria Player (Garritan's player) itself. There's nothing on the main buss. This was a rough mix, and I probably intended to go back and work a bit more on it but got distracted with other things. There's nothing on the main buss at all. I'm sure it could benefit from some compression to make it sound bigger.
Yes the Garritan samples are kind of pre-tweaked. And there are some effects you can add in the library too.
