Setup??~~!!
  • Thread starter Thread starter spongebath01
spongebath01
This has something to do with computer recording so i'll just ask it. Is this setup fine...
Guitar/Effects/Amp/Hum Elimantor/Mixer/Soundcard/Laptop
Also if i want to record jam sessions and i hooked everyones gear/mics up to a 10-track mixer and sent it as one track to a soundcard then to cubase, would the only way i could mix be on the 10-track mixer, or can i use the comp?
Depends on the amp and whether you will be satisfied with the sound of direct guitar. Does the amp have a Line Out or Direct Out?
Well, once you take ten inputs and mix them to a stereo output, and record the result, how would you propose to be able to separate the stereo track into component parts that would allow you to mix afterwards on the computer?
