Selecting Delta 1010LT jumper settings...
  • Thread starter Thread starter Drummerbones
Drummerbones
Drummerbones
I just purchased a Delta 1010LT and I'm reading the manual about setting the jumper settings on the XLR inputs. I'm a little unsure as to what settings I need. What do most of you set these to? I will run everything through a pre before it hits the PC (I could've done without the XLR's entirely), so I assume I need to set them to +4 line level. Am I right?
Thanks
That's what I set them to and it seems to work well since I'm using a +4 output.
Thanks
Sounds like you've got it right. If you don't want to use the built in pres then set the jumpers to line level.
Bear in mind even with the pres bypassed those xlr ins are balanced so are still potentially better than the other unbalanced RCA ins.
