J
J Man
Hello!
I'm looking for some help on building a drum room in the basement of my house. Feel free to be as general or detailed as you want, I'm looking for all the info I can get.
Here's the situation: I am looking at an area of about 320 square feet of basement space. Two concrete walls, one block-type basement window. I will need to build two new walls and put a door in. I have three recessed flourescent light boxes located above the floor joists. The room does not need to be 100% soundproof, but I want obviously to get as much reduction as possible.
My thoughts are that I will need to frame the outside walls with standard 2x4's and 5/8 drywall, anchored to the ceiling and floor about a 1/2 inch from the concrete walls. The interior walls will probably need to be a double wall of 2x4's and drywall with similar space between them. The ceiling will probably need to be resilient channels and drywall, and the floor will be rubber gym-style floor tiles.
I'm not 100% sure on any of this though. I don't what to do about the lights, if I should move them down below the drywall ceiling (which would be very low, if not too low) or put some type of lens over them. I don't know what kind of sound leak that would create. I don't know exactly how to construct the double interior walls or if that is necessary. I also have questions about the door, if it should be a double door, a door with perhaps a cover of somekind... And finally there would be no ventiliation to the area then, which is good for keeping it sound-tight, but not so good for those inside.
If any of you experience fellows can offer some input on any of this it will be GREATLY appreciated! Thanks!
