I just spent 2 days cleaning my console.
Pulled each channel group...disconnected all the wires...put it on a bench, sprayed the knobs/pots *from the back side* and then worked each one for several turns (my fingers are raw).
Pulling the knobs off the top and just spraying, rarely does anything more than make a mess. If you pull the knobs, in most cases you will find a nut that holds the pot in place....there's NO way to get any DeOxit past that and actually down into the pot where it's needed.
Not to mention...many decent quality pots....are sealed! They are not like typical guitar/amp pots that have small holes in the casing so you can spray in there easily.
If you can get to the back of the pots, instead of spraying...use a brush and tab some DeOxit around the tabs that hold the pot together and the edges of the pot...and some of it will get in there. Spraying just leaves a mess.
I took my can of DeOxit and just sprayed it into a small bottle until the can was empty...no I just dip the brush and go from there.
You can also buy DeOxit in a bottle.
AFA the faders, my console has Alps faders and pots, and likewise, spraying from the top crack doesn't really do the trick. The Alps faders actually come apart after you remove them, and you can clean the carbon tracks with a Q-Tip. Caig Labs has a specific cleaner for that....D-100.
You don't want to use any old "DeOxit" spray...'cuz it may mess up the action of the fader.
Anyway...it's a time consuming PITA...but now my console is all fresh and shiny
and ready for action.
Though I still have to do maintenance cleaning on my patchbays and other gear.
