You might want to check out this review, as I'll be referencing it a bit...
http://www.tomshardware.com/video/01q3/010927/index.html
I don't currently own an Audigy, but Tom's ran some pretty extensive tests.
Here's a quick spec comparison - I'm looking at the pages for the Audigy Platinum and Live! Platinum, at the Creative website.
The Live uses the EMU10K1 chip for MIDI, and the Audigy uses the EMU10K2. Difference? Beats me.
Now, according to the website, the Live can address up to 32MB of system RAM, while the Audigy can address up to 1GB. People have said that they can use bigger soundfonts on the Live, though. But, I think it's possible that they're simply compressing those soundfonts with SFArk.
The Audigy has a 32-bit effects engine for MIDI.
Both can record at a maximim of 16bit/48KHz, but the Audigy can play back at 24/96 - presumably for DVD audio discs? Although you can't record at 24 bits, the 24 bit DAC is going to make any recording sound better than it would have with an older card. I think that the card would make a perfectly fine inexpensive recording solution. IMO, most people don't have the other equipment necessary to take full advantage of a "prosumer" 24 bit sound card, anyway.
The Audigy supports the newest version of the soundfont format, which supports "sound variation in real time." Utopia, probably the best soundfont maker, is in the process of redesigning their flagship soundfont to take full advantage of the Audigy.
The Live has a SNR of >96dB, while the Audigy's rating is 100dB.
It also has a firewire connector.
It's $62.
More details, from the Tom's Hardware review:
Here's what the frequency response curve looks like, from 20Hz to 20kHz. As you can see, it dips some above 16kHz.
This is the card's noise floor, about -96dB.
I'd be curious as to how these specs compare to other cards - I really don't know. I'm sure they compare very favorably to other Creative cards, of course.
"the 16 and 24-bit recording modes are there and they work. But in fact, the card converts from analog to digital in 24-bit, after where is a 16-bit downmix which is finally restored in 24-bit by the software for the outputfile. So, it is not complete 24-bit recording process but the quality is improved compared to standard 16-bit by the use of the better converter. "
