saving vocal settings
  • Thread starter Thread starter snakeoi8u2
snakeoi8u2
Just got cubase LE4 with a zoom R16. When I get a vocal sound that I am happy with I can't figure out how to save all the levels so I can use them on other songs without having to start from scratch every time. I could also use some pointers on how to double the lead vocal track just to give it some depth.
You could erase the tracks themselves and save as a template. Frankly i wouldn't bother as each new projects vocal will almost certainly require differant settings. Just keep in mind how you treated the vocals or save your own presets in the effects themselves.
As for doubling the vocal track right click on the track bit where the buttons are and from the dialogue box choose duplicate track. Again this probably wont thicken it only increase the volume. Your better off double tracking the vocal to thicken it.
Right click on the name of the track in the mixer window and select "save this channel" or something like that.
In your new project select the channel you want to apply those settings to and right click on the name of that and load up what you saved above.
There is an easier way in the full version, but I just checked and it's not available in LE.
I like the template idea myself. Yeah, each song will require different settings, but if it's the same person playing the same genre, etc.. the saved parameters in the template will be a good starting point.
ymmv...
