running multiple tracks through compressor
  • Thread starter Thread starter daveblue222
D
daveblue222
i have 4 guitar parts that i have panned and want to use t-racks vintage compressor on all four of them, how do i do this without inserting the plugin 4 times (once on each track) can i create an effects track and send each of the tracks to the compressor that way?? or will this not work efficiently
all help much appreciated
dave
Project -> Add Track -> Ad FX Channel (or at least that's how it runs in SE3; it should be similar enough irrespective of the version of Cubase being used). You then specify the effect and blend the processed signal with the dry signal via the 'send' button on a given channel strip.
Or at least that's the theory and how it would work with things like delays and reverbs with wet/dry ratio set to 100/0. Generally, EQ, compression, gates, and gain staging are better to suited to being used as inserts as track transients differ quite a bit. the exception is drums which generally take a compression bus quite well. If RAM and CPU power are an issue, you can always bounce the individual tracks down with the effect applied - it'd be good idea to turn off the effect and disable the original track, which means it's always there should you wish to tweak the compression settings.
I like the T-Racks stuff, warms things up nicely when used sparingly.
you could also use a group track, route the 4 guitars into the group track and then compress the group
