T
thathatha
Running into a consistent problem with the Tascam DP-02cf 8-track..."No Disc Space"
Hello.
I have a quick question. I am using the dp 02cf 8-track recorder, and it works great apart from one problem that makes it impossible to use past a certain point.
When I record a track, it increases the data size of the song, which makes sense. But when I "clear" the track, the size of the song doesn't go down...this means that I can record, say, four takes of a part on the same track, clearing it each time, and it would fill up as much space as if I had recorded it on four different tracks. Eventually I get the "No Disc Space" message, and the machine will not hold any more data until I delete the entire file.
Is there a way to prevent this from happening? Or am I doing something wrong?
Thank you, and I look forward to hearing back,
Kevin
Hello.
Kevin
