jpmorris
Tape Wolf
Okay, I managed to acquire a recently-serviced MSR-24 which appears to be working, though without much tape, and with slight keystone wear on the head, I haven't been able to run a full test yet.
I am currently trying to figure out how best to integrate it into my setup, which currently consists of a 16-track desk and two synchronised TSR-8s.
The snag is, I want to keep one of the TSR-8s as part of the system, for simple songs that don't need that many tracks, and for vocals.
What I'm thinking of doing in the latter case is recording the body of the song to the MSR-24 and then bouncing a scratch track to the TSR-8. Then I can record the vocals over and over and over again - and keep some alternate takes - until I'm happy and then dump the vocals back to the 24-track for the final mix.
My current plan is to see if I can get hold of a relatively cheap and compact 20 or 24 channel mixer. One track is going to be timecode anyway, and this narrower format probably wants a guard track on 23, so I figure that 20 is okay - especially if I miss out the edge tracks.
Anyway, this introduces a little problem. How to monitor the TSR-8 and the MSR-24 at the same time? I don't think I can justify a 32-channel mixer, or fit it in the available space. I will need the ability to route the TSR-8 into the MSR-24 for bounces.
Current ideas are:
1. Have the TSR-8 permanently wired into the MSR's inputs. Things which get recorded to the MSR-24 pass through the TSR-8 in input monitor mode. Easiest with what I have, and extremely flexible. However, it does mean that everything passes through the TSR-8 which may add a few more op-amp stages to it (I'll have to check the card schematics to see how monitoring works).
2. Get a horrifically expensive and massive 32-channel deck. Route everything into the MSR-24 and somehow abuse the INSERT functionality in the mixer to allow inputs to be routed to the TSR-8 instead.
3. Build some switching boxes (e.g. with 4 stereo switches) to allow me to route the signals as needed. This will be a pain in the ass.
4. Mess around with patchbays constantly.
I dunno if anyone else has done this kind of thing. Any ideas?
Hmm, I should probably draw up a signal diagram of what I've got at the moment, since my explanation probably doesn't make sense
Current ideas are:
