stevieb
Just another guy, really.
Picked it up cheap- but a few keys won't trigger, two are LOUD, like you are hammering on them hard (keys are pressure-sensative) even when using a very gentle touch. Non-triggering seems to move around a bit, even tho I took it apart and cleaned the thing well, and used spray contact cleaner on the triggers.
I read of some stuff you can paint onto the trigger pads, but it's expensive, and I only need a very little. Also don't want to take the rubber trigger rows off again- a couple of the little rubber tits began to pull off and I don't want to lose them. I can get the spray straw under them, the spray also gets under them from can pressure.
But I am going NUTS chasing this thing around. Any experienced-based suggestions?
