RNP, Grace 101, Joemeek VC6Q, or VTB1
  • Thread starter Thread starter Kelsey
ozraves.
Would you say the grace is twice as good as the RNP?
Or would you just say that they are both excellent preamps, just for different uses?
I would think that having a grace 101 (or a pair of them), AND and RNP would give you a nice variety. From crystal clarity, almost to a fault, to a little bit of colour.
ambi said:
ozraves.
that's about it: both are excellent. the grace is more readily apparent as a high quality pre. the realism of the grace is kind of like those photorealistic paintings such as:
i think the grace is a little bit better pre but i could see someone else thinking differently.
I have never seen a picture of the back panel of the Grace 101. Does it have 1/4" unbalanced output capability, or would that require some sort of adapter? The RNP clearly is capable of connecting to an unbalanced line connector, but I can't tell about the Grace 101 from what I've read so far.
The Grace 101 has an XLR and a TRS out. However, it has a unique wiring scheme. Depending on your set up, you might need to get a TRS or XLR and have a 1/4 plug wired on the other end according to Grace's specs to connect to 1/4 unbalanced. It's no biggie.
