C
CyanJaguar
the vmp-2 is something of a beast. I used it today and it was awesome. The sytek sounds smoother in the headphones but the vmp-2 sounds more fluid and huge. This is the best that my voice has ever sounded thru a pre. The sytek is smooth and clear but a bit small sounding. The vmp2 is huge and spicy.
It costs around $600 -700 for two channels which I believe is cheaper per channel than the rnmp, when it eventually comes out.
For those who are wondering how this beast sounds, I have some tests on Vox.
This was the 4033 into the vmp2 after about 1 hour and 15 minutes of warm up. The eq was switched off. I think it sounds more ballsy when the eq is switched off even though its not using all six tubes.
I used the blueberry on this one. I engaged the eq but left all settings on zero. Also, both tests had the 40 hz high pass on.
