bigwillz24
Okay i read the manual for the rnc after many hours of trying to make the thing work with my patchbay and came up with this.
NOTE —
Hooking up the RNC to balanced lines with TRS 1/4'' plugs will not work! If
the equipment you are connecting the RNC to is balanced, you must first unbalance it and only connect into the RNC with TS 1/4'' plugs.
Okay so how do you unbalance a patchbay?
Note: At least they put balanced out on the RNLA it works the pachbay no problem.
NOTE —
Now all I gotta do is figure out why the outputs of
