T
themaddog
Rockin' & Rollin'
Hey everyone,
I've been trying to figure out which tape I'm going to use to mix my band's new album. Today I made the same mix onto SM 468 and SM 911. All of the signals were the same going in and out (as much as possible), the only exception being the final level going onto the SM 911 was about 3 decibels softer than the 468, otherwise it sounded too muddy and "garage-band."
I've uploaded each track here, but each download will likely take you awhile as they're 16-bit/44.1khz .wav files. The name of the song is "The Night Stalker."
http://www.nightstalkermusic.com/rmgi/ns468.wav
http://www.nightstalkermusic.com/rmgi/ns911.wav
The difference between the two was far more dramatic directly off of the tape, although you can hear some subtle differences in the tones on these digital versions.
To my ears, the SM 468 sounded much fuller. It is what I'll be using for the rest of the album.
-MD
More info for those who are interested:
The source was originally recorded on an MSR-16 using Emtec LPR 35 "Special Run" tape. The mix down machine was an Otari MX-50 NII. While mixing, I used the repro head off of the Otari to find the best signal level for the particular tape I was using. For the SM911, this meant that the signal had to be a little softer. When it was recorded onto computer, a Delta 44 sound card was used, at 16-bit/44.1khz (no dithering), at the same level for each mix. No computer adjustments were made, other than cleaning up the beginnings and ends of the tracks.
-MD
