A
ajfriedman
I've got a little problem with echo in some of my recordings.
I record spoken word for broadcast on a Reading Service for the Visually Impaired.
I use a Shure SM58 mic, a Eurorack mixer, into a generic soundcard on a Dell Laptop, using Cool Edit 2000.
I make mono wav files at 22.05 KHz, which I copy to a (data) CD.
The CD is taken to the Reading Service studio, where the files are copied to the studio's computer hard disk. The Service uses software called Wire Ready for scheduled playback of its recorded programming. Programming for Air is fed via ISDN phone lines to a public TV station, where it goes out over their SAP channel, and also on a web site for streaming audio.
Here's the mystery:
When I play back the wav files from the CD through my computer on my speakers or headphones, the sound quality is fine. When I listen to the broadcast over a SAP broadcast receiver (analog), the sound is also fine.
When I listen over the internet, it sounds like I'm at the bottom of a well. There's a slight ringing, and the faint hint of ocean surf, neither of which are present on the CD. These artifacts aren't present when I listen over the internet to recordings that I've made at the Reading Service studio, only on those I've made at home, and copied to CD.
Question: I would have thought that copying a recorded wav file between a CD and a hard disk would not introduce any distortion.
What could be causing this? What can I do about it?
Here's the mystery:
