Take a close look at the frequency response charts of those mics.
The PG56 is only efficient down to about 200 Hz and it has some hype from about 2000 to 8000 Hz. I feel this would be much better suited on the snare drum. On my own snare drum tracks I usually push that upper frequency range to give the drum more life and crack anyway.
Next the KSM27 has gorgeous rich lows down to 20 Hz with a slight hump at about 50 Hz. OMG, what more could you ask from a kick drum mic? Stuff that sucker inside at about 6 or 8" from the batter head. But tilt it slightly off axis so the sound pressure doesn't destroy it.
Put the SM57 on the high hat and roll off all lows and mids. Now you can bring the HH's up or down at key places in the music.
Use the ribbon for overhead because it will pick up some rich lows from the toms and the cymbals won't sound too harsh. Ribbon mics sound far more natural and are easier to EQ than other types. Most ribbons are "side-address" and don't like phantom power or wind. Carry them across the room slowly.
There you go,
Hope this helps.
