I know what you mean. I have a 50kw transmitter locally. Not that close, but it gets into a lot of my electronics. I find that good grounds help a lot. Be especially careful to make sure you electrical system is up to code. The ground is very important.
Another thing you can do if you can solder, is put a lot of 0.01ufd or 0.001ufd capacitors all over the place. Put them across the hot to ground all over the place. The more the merrier, but I would use the 0.001 so that the high frequencies are not effected.
Try these, I've had good luck with this kind of fix.
