A
acanthusarch
I have just installed a combo-cable with 12 individually shielded cables (3 conductors each) to carry 12 channels of audio from a Studio Room to a Control Room. I have 10 XLR type and 2 1/4" Type wall connecters at each end installed in a wall plate. I soldered all connections, and when testing get signal accross the cable, but I also get a lot of RF interference in the form of AM/FM radio. I have tried doing some experimenting with some aluminum foil to shield the connectors to see if this affects the noise, but it doesn't. Is there any way to shield the connectors from the RF?
Also, I am wondering if the issue has nothing to do with shielding, but grounding. The cables are of course connected to the wall plugs which are connected to the metal wall plate, but the wall plate is not grounded at either end. Is this the cause of my problem, and if so what is an easy way to ground it.
Thanks for any help you could give.
Jason
Jason
