ReWire2 Problems: Cubase and Reason Trouble
  • Thread starter Thread starter ScienceOne
ScienceOne
Ok, so when I installed Reason with Cubase vst 32 already on my computer, Cubase worked fine. Reason would not open; there was a warning box that said something to the effect of "Rewire2 cannot be opened." And it would not let me open Reason. Reason included some progam that fixed this problem (apparently there is a Rewire2 problem between certain versions of Cubase and Reason). I clicked on it and it told me that the problem was fixed, but Reason still does the same thing. Even when I uninstall and delete Cubase, Reason still pops the little warning up. Please help me. I must have Cubase, and I hate to think that i wasted all my money on Reason when I cant even use it.
I don't have Reason so I ripped this info for ya, hope it works. VST32 5.0 should work with rewire & reason. You need to be sure to launch cubase first and then make rewire active by selecting rewire from the pannels menu. After you make rewire active, enable the rewire tracks by clicking on the little green tabs next to the audio tracks that are made available in the rewire window. Then you may launch reason. You can import & export audio a few different ways. You may also audition VST processing & it is all n-sync with cubase.
Thank you very much. Hey, I bought a ComposerPro, here's to better vocal tracks! THanks a lot for the advice......... again.
Ya Hoo! Have fun with it. Read that manual a few times too. If full of good ideas.
well wait, is the old composer 2100 better than the new composer 2200, ive heard that it is.
