antispatula
Active member
hey, anyone have any good suggestions for a reverb unit? I've had my eye on the Fostex 3180, but have no idea if it's decent or not. Thanks!
cjacek said:I would recommend a Lexicon LXP-1. It's an older, now discontinued digital reverb at its best, performance / price wise. Tim, if I recall correct, you do have a review of the LXP-1, don't you ?![]()
Beck said:By the way, I'm not a fan of spring units, ...
As for which spring is better or what supporting electronics for that spring is better - I'd say: forget about it.... they are all just bunch of different things... non of them are better, non of them are worse.... all depend on what you expect from it and what you use it for. Another words, let me say this (as example) - let's say, Fender '65 Twin Reverb is a great amplifier, but you would not want to use it to enjoy Bethoven's 9th Symphony in D minor, Op. 125 ... because it's not so great for amplification of such material and in such situationBeck said:... but if you must, I would go with a Furman RV-2 over the Fostex or Tascam.
Herm said:And here is a short bit of a song we did with the 3180 on vocals
When I need to "put" something into a virtual room or hall I use DigiTech TSR-6... 'stone age' digital reverb (also has some delays which are not bad... )... works perfect for me. It has three knobs predelay/decay/level ..which can be turned into freq/Q/gain eq by the push of the button and there is another button called 'store' ... push it and you've saved the program ... and it does not asks you : "Are You sure about re-writing the program?" lol , - perfect!Beck said:Reverberation is one thing digital does very well.
Herm said:I kinda like my 3180 also but have never found a Bass or treble control anywhere on it
antispatula said:The only problem is, I have a terribly unhealthy prejudice against digital recording units altogether......I can't help it! I think it's a mixture between being a White Stripes fan(atic) and just spending so much time on my recorders that I don't want to use digital at all.....Yes, I know it's unhealthy, I can't help myself though!
