miroslav
Cosmic Cowboy
OK, I know there’s no absolute answer…but from a subjective position, I was curious how folks approached Bass and Kick reverb application during their mixing adventures.
I tend to apply maybe only about 30% (of whatever my “global reverb” sound is) to the Bass and Kick tracks…though that’s somewhat of a generalization…but basically, I don’t like to run them totally dry if I’m using any reverb on the rest of the drum kit or guitar tracks.
I like to think about my mix in terms of an overall “room” sound that places all the “players’ in the same room....and then I will adjust my global reverb to-taste on those different elements.
I usually have 3 different reverb units running during my mixes (talking about outboard gear and a real mixer…not ITB).
I’ll have my main reverb unit set up primarily for the vocals (most often I’ll go for some type of plate setting, not always ), and I may also use that same unit/sound on some instruments as well if it works for them.
My two secondary reverb units are mainly for the instruments. I’ll set both of them with the same type of room/hall sound, but one will usually be set with shorter delay time than the other. That way I can have the same room sound, but with differences in reverb depth between the two, and then, depending on the song and the instruments and all the other variables…I’ll pick which instruments will be bussed to which unit. Organ may go to the reverb with the longer delay time…and drums to the shorter, and of course, the amount of reverb level will be set at the mixer for each channel/track…and this is where I’ll only give the Bass and Kick about 30% of what I set for the rest of the kick or some of the other instruments.
But I’m always wondering about the Bass and Kick…and sometimes I want to give them a pinch more reverb in the mix, but I don’t want to risk overloading the low end reverberation and possibly cluttering up the mix…though I don’t like the idea of making them 100% dry, either.
So I was curious how far people like to push that…or not at all….
