Then if I want to adjust one channel fader I would have to disable groups or deselect the group every time then tweak the send as well. Why does Avid put us through all that crap when a simple
logic circuit solved this problem in the 70s and every other DAW has followed that industry
standard? It's completely nuts, but so many Pro Tools users have never used an analog board or other DAW long enough to see how lame the Pro Tools soloing is.
Why would you disable the group then adjust the main track fader
and the send?
Grouping
the tracks saves you the bother.
I'm not denying it's inconvenient if you're from the 'old school', but let me get this
straight.
In the real
world your send is post fader but pre solo/mute right? So adjusting the track fader adjusts the send level too, but muting the track doesn't mute the send, (or soloing the aux works) yeah?
If so grouping your track and aux faders whilst set in pre fader mode should achieve the same result.
Pre fader mode gets you the mute/solo functionality that you want, and grouping the two faders makes the set up act like it's a post fader send in terms of maintaining wet/dry balance.
It might not be perfect. I appreciate that the gain staging is a little different, but I think it'd work just fine.
Yes, you'd have to ungroup the two tracks if you want to adjust the balance, but that's not much of a tradeoff.
An experienced man like yourself is likely to have the balance set very quickly anyway, right?
Admittedly it'd be a lot better if Protools sends were post, pre, and something in between.
I'm not trying to argue a point with you; I'm trying to offer a solution.
The the OP. Sorry for the tangent. Feel free to reclaim your thread any time.
