BeniRose
I've been mixing using the built in reverbs that came with Logic Pro, and they get the job done, but I'm struggling to find the right volume for my reverbs. The problem is, I don't like my verbs to be super noticable, so i'll keep them back in the mix, or find one that isn't so obvious, but then when the dynamics change like some imstruments drop out or something, it sticks out like a sore thumb. Now I know the obvious fix to this is automating the volume on my reverb sends, but I wasn't sure if this was the proper solution or if the problem was rooted in something else in my verb, maybe if I'm using the wrong kind or the ones logic provides are just really obnoxious and difficult to keep subtle in dynamics. Is anyone else having similar problems, especially on vocals?
) If that's indeed what you're looking for - and it often may be - that's fine, read all of the above.
) is to simply use too much of it. I'd at least try setting it so that it sounded good during the quiet parts instead of during the busy parts. It may or may not sound like there's not enough during the busy parts, but you might just find that it actually works that way. if not, then just try nudging the verb up just a little; possibly a compromise level between the two may work.
