Secret Clubhous
Sometimes in the heat of creative passion
I forget to change record mode settings, & end up with something I didn't plan on. Like I had intended to store takes in a single track but neglected to turn off the loop function or the "store takes in different tracks" option. So everything ends up either stacked on top of itself or split up into separate tracks. Sometimes this turns out to result in something even cooler than I would have come up with originally, but sometimes it's a pain to manually extract each take to different tracks &/or paste it all back together seamlessly.
Or I forget to set it to record mono & it defaults to recording stereo, which is unnecessary & then I can't pan in the mix.
So my question is:
Is there a way to undo these record settings after recording, which doesn't require tedious manual editing?
I forget to change record mode settings, & end up with something I didn't plan on. Like I had intended to store takes in a single track but neglected to turn off the loop function or the "store takes in different tracks" option. So everything ends up either stacked on top of itself or split up into separate tracks. Sometimes this turns out to result in something even cooler than I would have come up with originally, but sometimes it's a pain to manually extract each take to different tracks &/or paste it all back together seamlessly. Or I forget to set it to record mono & it defaults to recording stereo, which is unnecessary & then I can't pan in the mix.
So my question is:
