resetting eq?
  • Thread starter Thread starter rightbrainnow
R
rightbrainnow
Using cubase SL3...is there a way to reset the eq? In other words...I goofed and eq'd the wrong track...and without having to manually go in and bring all the eq back to normal...is there a function set up where i can just reset it quickly?
i use sx3 but i guess its the same. i think you can only reset back to the default and not to where you had it set last. click on the edit audio channel settings icon for the track in question (its the letter e symbol), you will then open up an audio channel settings window, in this you will see your eq graph and above this some more icons you can click on, just hover over them with your pointer until you see reset eq's.
