Yes...very true, though I wonder how many folks that ever used the software had or got a true reference measurement mic?
If they're not, then what they're doing is basically useless.
I'm not downplaying the need to use one...just saying that most probably don't.
I would hope that it's inherently understood that a measurement mic is a necessity. It's certainly in the instructions somewhere...
Of course, you then have to consider what "color" the non-reference-grade mic is adding to your measurements and how accurate then is the measurment...?
Like....do you get ANY benefit at all using a high-end, but not a "reference grade" mic to take some measurements...?
Not really, no. Well, let me clarify -- If you're using an Earthworks M30, Avenson STO2, some sort of omnidirectional electret condenser with a freakishly small capsule and freakishly fast response that might not be
marketed as a measurement mic, it could theoretically be used as such (with the proper calibration file, of course). At the very least, it would hopefully be flat (or at least consistent) enough, fast enough, have zero proximity effect and zero off-axis rejection, etc.
I used the REQ once awhile back...and can't for the life of me remember which of my mics I used....though it was probably one that had the flattest response.
Since you're pluging the Behringer...
....I may drop the $50 and get it.
Get two. I can't even imagine not having a pair of omni condensers for recording...
It's not the raw quality of the mic here -- It's simply what the mic is designed for. You can't (CAN'T - as in "It's not possible, period") measure room response with a cardioid element. You can't do it with a $9000 Sony 800 either -- The "high-endness" of the mic isn't the problem. The highest-quality table saw would be terrible tool for hammering a screw into a board.
You DO have to consider what coloration your mic is adding -- with reference mics. There are calibration files to use with different reference mics (even for the Behringer). But you still need a reference mic. There are cheap-n-effective reference mics out there all over the place. Many are "no-name" (the kind you get with JBL subs and what not) that will work fine. Even without a calibration file for the most part.
You need a SPL meter to do any of this anyway -- Usually the mic built-in to those meters are flat enough (assuming it has an output).
