F
fozzy1987
Hi, I've looked on the forum elsewhere but am still having difficulty replacing the capstan belt on my Tascam 488. As someone with very little experience doing a DIY job on recording equipment in general, I'm confronted by a mass of wires when I get the front case off which is making it difficult to actually get to the motor and capstan belt itself.
It's a case of knowing (roughly speaking) how to get the belt replaced once I can get to it, but finding a number of hurdles standing in the way. I don't want to run the risk of breaking any vital connections on the circuit board - as I don't have the know-how to correct my mistakes - but at the moment can't get the leverage to lift the front casing and make the task manageable. I've heard that the back case (the metallic section in the top right) should be removed instead of trying to get at the motor from the front and wonder if that is indeed the case or whether the best tactic is to disconnect the wiring and remove the motor unit altogether.
Any advice would be hugely appreciated!
fozzy1987
fozzy1987
