P
Peter B
Guest
I'm new to home recording.........so new I don't even know if I've posted this in the right forum, but here goes anyway.
I'm using Cubase to record solo sax and sax quartet at home. Everything's going OK, I'm learning fast and my recordings are improving gradually as I get a bit better at micing and using tools like compression, reverb and EQ. There's one function in the Cubase audio processing list that I don't understand though, and there's no explanation of it in the help files so I'm hoping that someone can explain it to me.
The effect is listed as 'Remove DC Offset'. Now if I apply this function to a selected track, I get a progress bar up on screen which runs quickly from start to end in a time depending on the length of the track, and that's it. I can't hear any difference in the track after applying this effect.
So I should be grateful if someone could shove me a bit further up the learning curve by explaining: (a) what DC offset is, (b) How I know if I've got it, (c) Why it needs to be removed, and (d) If it does need to be removed then why is it a selectable function which implies that you have the choice of leaving it there. If it's bad and needs to be removed why isn't it just done automatically to all tracks out of sight and out of mind?
Thanks in advance for a quick lesson on DC Offset.........
