NL5
Unpossible!
Let me know what you think - it was tracked a couple years ago or so. Thought I'd take another crack at it this morning on a whim.
New Mix -
New Mix -
Sounds really good to me Gunnar...I hear nothing I could suggest to do different.![]()
YO!
I like it, a bunch. Most anything I could offer is subjective, but here goes.
I know that tracking was completed on this a couple years ago, but I might suggest tracking a few more guitars, and panning them hard for a nice big stereo spread. It just seems that there is a lot in the center... acoustic.... the electric sounds more stereo, but I can tell there is only one track there. That, and I'd like a smidge more kick drum.
Very nice, on the whole. Good job!
~Shawn
i can't comment on tone...sounds great. changing anything would be stylistic. i don't listen to enough pop to know what it "should" be.
the lead vox don't sit sometimes. as stated, the takes could be better. it sounds like the singer can do better, but these aren't his best. in the chorus "i can" - those need more vocal support. the "am i over my head now" could definitely go for another couple takes. oh...and they're slightly dry i think. i know you automate it briefly for transition from chorus to verse...but a little more reverb the whole time might help. not much though. just a little
did the band recommend the laugh at the beginning?
i think if you could take the lead guitar before the build up...copy it and put it to another track
cut the first repetition of the "ti-do so" of the riff off ...tack it to the end.
in effect you would be double tracking it without another take.
but as it builds, make the original and the double widen with automation.
just an idea.
Ok, I took a lot of the suggestions, as well as some issues I had after listening for a bit. I don't know if this is much better. I have discovered that the bottom end changes when I export the mixdown, and again when it converts to MP3. Each conversion seems to deepen the lowend. Odd.
The laugh was kind of a joke. I think it needs something in front of the song so it doesn't start so harshly.
I did some stuff with some vocal takes I had, don't know if it's better. i need to go in and tighten up the timing.
Better?
Well MP3 sucks anyways !
Stupid invention, it killed the hifi !!
